PROBLEM
Unable to add a dynamic workspace to a map service
When attempting to add a dynamic workspace to a map service, the loading process stops responding.
User-added image of dynamic workspace loading dialog box
Cause
The PublishingToolsEX geoprocessing service is missing, thus preventing the action of adding dynamic data sources to the map service. The ArcGIS Server Logs report the following warning message:
Error:
Unable to process request. Service System/PublishingToolsEx/GPServer not found
User-added image
Solution or Workaround
To resolve this issue, recreate the PublishingToolsEX geoprocessing service:
  1. Sign in to ArcGIS Server Manager.
  2. Navigate to Services > System > PublishingTools.
  3. Click REST under Supported Interfaces and copy the resulting JSON.
  4. Navigate to Services > System and click Create Service under Supported Operations.
  5. Paste the JSON from Step 3 and replace the provider and service name to the following parameters:
    "provider": "ArcObjects11"
    "serviceName": "PublishingToolsEx"
  6. Click Create and add a dynamic workspace to the map service.
Article ID: 000018634
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
