PROBLEM
Unable to access a mobile geodatabase if the geodatabase name contains a comma
When adding a mobile geodatabase to the map in ArcGIS Pro and the geodatabase name contains a comma, ArcGIS Pro returns one of the following errors.
Error:
Unable to open database file (doesn't exist or no read access)[ ]
Error image for mobile geodatabase with a comma
Error:
DBMS table not found [no such table: main.GDB_Items] [GBD_Items]
Second error DBMS
Cause
Commas in mobile geodatabase names are not allowed in ArcGIS Pro, even though they are allowed in Windows.
Solution or Workaround
  1. Open Windows File Explorer.
  2. Navigate to the folder where the mobile geodatabase is stored in.
  3. Rename the mobile geodatabase to remove all commas in the mobile geodatabase name.
  4. In ArcGIS Pro, in the Catalog pane, right-click the folder connection with the mobile geodatabase and click Refresh.
Article ID: 000028352
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
