PROBLEM
When calculating the density of features for a feature layer using the Kernel Density tool in ArcGIS Pro, a blank output raster is generated, as demonstrated in the image below.
This issue occurs when the feature layer coordinate system is a geographic coordinate system. The search radius in the Kernel Density tool calculates the density based on the linear unit of the projection of the output spatial reference. Thus, the coordinate system of the feature layer must be a projected coordinate system.
Note: To check the coordinate system of the feature layer, refer to the Tip section in ArcGIS Pro: Specify a coordinate system.
To resolve the issue, project the feature layer to a projected coordinate system using the Project tool, and calculate the density of the features using the Kernel Density tool in ArcGIS Pro.
to specify the location for the output feature class.
to open the Coordinate System window.
The image below shows the output raster generated by the Kernel Density tool in ArcGIS Pro.
Article ID: 000026358
Get help from ArcGIS experts
Start chatting now
