PROBLEM
The Edit with IDLE and Run with ArcGIS Pro options are not available in the context menu when right-clicking Python files
Last Published: October 24, 2025
In some instances, when right-clicking Python files, the 'Edit with IDLE' and 'Run with ArcGIS Pro' options are not available in the context menu.
Image of the the Edit with IDLE and Run with ArcGIS Pro options are not available in the context menu
Cause
A possible cause is that the default app to open the Python files has changed.
Solution or Workaround
Select one of the options below depending on the cause to resolve the issue.
Select python.exe as the default application to open Python files
  1. Right-click the Python file, and select Properties.
  2. In the Properties window, click the General tab, and click the Change button next to Opens with:.
  3. In the Open with window, click the Browse button.
  4. In the Open with… window, paste the following path in the address bar, and press Enter.
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
  1. Select python.exe, and click Open.
Image of the Open with... window
  1. Close the Properties window.
The following image displays the availability of Edit with IDLE, Edit with IDLE (ArcGIS Pro), and Run with ArcGIS Pro options in the context menu.
Image of the Edit with IDLE and Run with ArcGIS Pro options are available in the context menu
Article ID: 000024926
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
