PROBLEM
The 20 MPH symbol is unavailable in the Esri Transportation & Civic style
Last Published: July 21, 2022
The 20 MPH symbol is unavailable in the Esri Transportation & Civic style in ArcGIS Pro and ArcMap.
Cause
This is a known limitation.
Solution or Workaround
As a workaround, complete the following steps:
In ArcGIS Pro
  1. In the Contents pane, right-click the desired layer, and click Symbology.
  2. In the Symbology pane, in the Primary symbology section, click the symbol next to Symbol.
  3. In the Symbology pane, click Properties and click the Layers The Layers icon. icon.
  4. Click Appearance > Font. The Choose a character window opens.
The Symbology window displaying the Appearance and Font options.
  1. In the Choose a character window, click the Font drop-down, and select Esri Shields.
  2. In the Unicode section, select the 20 MPH symbol and click OK.
The Choose a character window displaying the Font options. Click OK.
In ArcMap
  1. In the Table Of Contents, right-click the desired layer and click Properties.
  2. In the Layer Properties window, click Symbology > Features, and click the symbol under Symbol. The Symbol Selector window opens.
The Layer Properties window, click Symbology and click the symbol under Symbol and click OK.
  1. In the Symbol Selector window, click the symbol under Current Symbol. The Symbol Property Editor window opens.
The Symbol Selector window, click the symbol under Current Symbol.
  1. The Symbol Property Editor window, under Properties, click the Type drop-down, and select Character Marker Symbol.
  2. On the Character Marker tab, click the Font drop-down and select ESRI Shields.
  3. On the symbol board, search for and select the 20 MPH symbol.
  4. Click OK.
The Symbol Property Editor window, in the Character Marker tab, select the ESRI Shields option and click OK.
Article ID: 000006532
Software:
  • ArcGIS Pro 3 0
  • ArcMap 10 6
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcMap 10 7
  • ArcGIS Pro 2 x
  • ArcMap 10 8
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
