PROBLEM
In ArcMap, when creating a mosaic dataset using the Create Mosaic Dataset tool and adding raster images to it using the Add Rasters To Mosaic Dataset tool, some rasters images in the mosaic dataset are not displayed on the map.
This problem occurs because there are mixed resolutions in the mosaic dataset. If the images in the mosaic dataset have different resolutions, the pixel size ranges in the MinPS or MaxPS columns are also different. This causes only images with the largest pixel size to be displayed on the map. For more information on MinPS and MaxPS, refer to ArcMap Help: Cell size ranges in a mosaic dataset.
To resolve this issue, set the maximum number of images to reflect the total number of images in the mosaic dataset. Then, set the MaxPS field for all the images to the largest pixel size listed in the field.
The image below shows all the raster images are displayed in the mosaic dataset after changing the maximum number of images and the pixel size in the MaxPS field.
Article ID: 000019948
Get help from ArcGIS experts
Download the Esri Support App
