PROBLEM
In ArcGIS Pro, when copying and pasting features to a new feature layer using the Paste Special command, the pasted features are not aligned with the original features.
The image below shows the copied feature layers, Houses and Orchards, are not aligned with the original feature layers, Streets and Gardens.
The destination feature layer uses a different coordinate system from the original feature layer.
Change the coordinate system of one of the feature layers to match the other using the Define Projection tool.
The image below shows the pasted feature layers, Orchards and Houses, aligned with the original feature layers, Gardens and Streets, after changing the coordinate system using the Define Projection tool.
Article ID: 000031936
Get help from ArcGIS experts
Start chatting now
