PROBLEM
Dates are not recorded for a Date and Time question submitted from the ArcGIS Survey123 web app
First Published: November 9, 2021
Last Published: April 29, 2022
The dates submitted to Date and Time questions through the ArcGIS Survey123 web form are not captured in the attribute table of the survey’s hosted feature layer.
Date and Time not captured in attribute table
Cause
The Date and Time questions require both date and time to be filled out on the form when the form is submitted through the web app. If only the date or time is filled out, the submission does not capture the date or time alone. However, the ArcGIS Survey123 web app allows users to submit the form and the datetime field remains blank in the attribute table of the survey’s hosted feature layer.
.When the date or time is unfilled, the submission does not capture the date or time alone
Solution or Workaround
Choose one of the following as a solution.
Make the Date and Time question mandatory
In the ArcGIS Survey123 web designer, edit the Date and Time question by checking the This is a required question check box.
Check This is a required question
Use the Date question
In the ArcGIS Survey123 web app, choose the Date question if time is not required. This option captures the time as 12:00 pm by default.
Assign a default value of 'now()'
  1. In ArcGIS Survey123 Connect, download and open the survey form.
Download the survey
  1. In the survey, click XLSForm to edit the questions.
  2. In the form, navigate to the dateTime field.
  3. Set ‘now()’ in the default column for the dateTime question. Save the form and republish.
Article ID: 000026776
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
