ERROR
Oracle error when the shape.area or shape.len attribute is not fully qualified when using a definition query with a layer stored using st_geometry
Error Message
When using ArcMap and defining a layer's definition query, if the shape.area or shape.len attribute is referenced in the WHERE clause but not fully qualified, an underlying Oracle ORA-00904 error is encountered.
The following statement encountered a error during parse:
SELECT 1 SHAPE, WATER_BODIES.OBJECTID, WATER_BODIES.SHAPE.points, WATER_BODIES.SHAPE.numpts,
WATER_BODIES.SHAPE.entity, WATER_BODIES.SHAPE.minx, WATER_BODIES.SHAPE.miny, WATER_BODIES.SHAPE.maxx,
WATER_BODIES.SHAPE.maxy, WATER_BODIES.rowid FROM TB.WATER_BODIES WORLDWATER
WHERE SDE.ST_EnvIntersects(WATER_BODIES.SHAPE,:1,:2,:3,:4) = 1  AND (("NATION" = 52 AND "SHAPE.AREA" >= .000010))
Error encountered: ORA-00904
Cause
The Oracle parse error occurs because the shape.area or shape.len attribute is not fully qualified with its table name or a table alias in the SQL statement being executed in the database.
Without fully qualifying the attribute, the shape.area or shape.len attributes are not valid attributes for the table being queried. The area and length attributes are properties of the st_geometry type and therefore must be fully qualified with the table alias when referenced within the SQL statement.
Solution or Workaround
The solution to the error is to fully qualify the shape.area or shape.len attribute in the definition queries WHERE clause.
For example when adding a definition query for a layer named 'water_bodies' in ArcMap, an Oracle parse error with the following syntax is encountered:
By fully qualifying the attribute with the table name, no error is encountered.
"NATION" = 52 AND "WATER_BODIES.SHAPE.AREA" >= .000010
Article ID: 000010328
Software:
  • Legacy Products
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
