HOW TO
Make Oracle database authentication connections using a Net Service Name
Summary
Instructions provided describe the steps to make Oracle database authentication connections using the Oracle Instant Client and a Net Service Name. See How To: Configure the Oracle Instant Client to make Database Authentication and Operating System Authentication connections using ArcGIS Desktop for more information.
Procedure
  1. Download the (32-bit) Oracle Instant Client from the My Esri, and unzip it to a location on the local ArcGIS Desktop machine. Change the name of the folder if desired.
EXAMPLE:
C:\OracleInstantClient_32
  1. Add the Oracle Instant Client path to the beginning of the existing PATH (operating system) Environment Variable.
EXAMPLE:
PATH=C:\OracleInstantClient_32;...
  1. Create a file called 'TNSNAMES.ORA' inside the Oracle Instant Client directory, and add an entry in the file specifying a desired Net Service Name, the Host machine name (with the local domain), and the Service Name.
EXAMPLE:
ORCL =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = ORASRVR.<yourDOMAINNAME>)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = ORCL)
  1. Create an Environment Variable on the Windows operating system called 'TNS_ADMIN' that references the location of the Oracle Instant Client directory.
[O-Image]
  1. Launch ArcCatalog and make a connection using the Net Service Name and selecting the Database Authentication option from the drop-down, and specify a username and password.
[O-Image]
Article ID: 000012021
Software:
  • Legacy Products
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
