Summary
                    The instructions provided describe how to make a dual-unit scale bar in a map layout.
                        Procedure
- Navigate to the Layout View of the map document.
 - Insert two scale bars; click Insert >  Scale Bar, and in the Scale Bar Selector dialog box, start by trying the 'Scale Line 1' and 'Scale Line 3' styling formats.
 - Right-click each scale bar and click Properties.
A.	On the Scale and Units tab, select the desired unit of measure from the Division Units drop-down menu.
B. On the Size and Position tab, check the box for 'Align scale bar to zero division.'
![[O-Image] Scale Line Properties](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011784/00N39000003LL2C-0EM39000000wdPb.png)
 - Line up the two scale bars by selecting each one separately and dragging them into the correct position so that the middle/common base lines overlap.
 - Select both scale bars by clicking both of them while holding down the CTRL key, right-click the scale bars and select Align > Align Center.
 - To save the alignment settings, right-click the selected scale bars and select Group.
![[O-Image] Align Scale Bar](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011784/00N39000003LL2C-0EM39000000wdPc.png)
