HOW TO
In Drone2Map for ArcGIS, by default, the activity logs only capture errors and warnings when running a project. To capture all errors and warnings when a project is not running, debug mode can be enabled. The instructions below describe how to do this.
Note: The logs are found at: %LOCALAPPDATA%\Drone2Map\log
If using Drone2Map for ArcGIS 1.3 or later, the logging level can be altered in the interface.
Note: Trace is the highest level of logging available.
If the option in the interface is unavailable, the logging can be set manually with the following:
"logLevel": "Trace"
	Article ID: 000013663
Get help from ArcGIS experts
Start chatting now
