HOW TO
Stop GIS services using ArcGIS API for Python
First Published: May 15, 2019
Last Published: July 3, 2025
Summary
ArcGIS Server services can be stopped from ArcGIS Server Manager, ArcCatalog, or the catalog window in ArcMap. In some cases, there may be several services that must be stopped, and stopping them manually is tedious. For federated ArcGIS Servers, the ArcGIS API for Python's stop() function may be used to automate the process.
Procedure
The steps describe how to stop services in a GIS folder using the stop() function.
  1. Import the necessary libraries.
from arcgis.gis import GIS
import arcgis.gis.admin
  1. Specify the GIS server details.
gis = GIS("<portal url>", "<portal admin username>", "<portal admin password>")
To bypass the certificate verification, add the parameter, 'verify_cert=False'.
  1. Retrieve available folders in the server, and specify it in a parameter.
gis_servers = gis.admin.servers.get(role="HOSTING_SERVER")
If the desired server folder array location is known in the list, the script can be modified to:
gis_servers = gis.admin.servers.get(role="HOSTING_SERVER")[0]
"[0]" can be modified to specify the exact location of the service in the array. In the example, the script grabs the first service in the list.
  1. Loop through the list and stop the services.
  • To stop all services:
for server in gis_servers:
    for service in server.services.list():
        service.stop()
  • To stop a specific service:
        print (service)
        if service.properties.serviceName == "<service name>":
            service.stop()
The following is the full script to stop the SampleWorldCities service:
gis = GIS("https://machine.domain.com/portal", "admin", "password", verify_cert=False)
        print (service)
        if service.properties.serviceName == "SampleWorldCities":
            service.stop()
Article ID: 000019994
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
