HOW TO
A custom printer page size can be set by way of the Windows printer properties. The availability of custom page sizes depends on the Windows driver.
ArcMap 10.x
To set the custom printer page size for ArcMap 10.x, refer to ArcMap: Setting the page size of your map layout.
ArcMap 9.x
Note: Turn off either the Scale map elements proportionally to changes in page size option, or Use Printer Paper Settings option so the existing map is not affected.
Note: This is a sample custom page size dialog box for the Windows driver for the HP DesignJet 5000PS. Availability depends on the printer's Windows driver.
ArcMap 8.x
Note: This procedure is not available for ArcMap 8.0.1 or 8.0.2.
Note: Turn off either the Scale map elements proportionally to changes in page size option, or Same as Printer option so the existing map is not affected. Click OK once completed.
The custom printer page size appears in the Printer setup information on Page Setup. The Windows printer engine, the PostScript, or the ArcPress printer engine can now be used for printing.
Article ID: 000003008
Get help from ArcGIS experts
Start chatting now
