HOW TO
Remove z-values or m-values from a feature layer in ArcGIS Pro
Last Published: September 26, 2024
Summary
If a feature service is published with m- and z-values enabled, it is not possible to disable these properties on the published service. Disabling these properties requires exporting data from the hosted feature layer, changing these settings in ArcGIS Pro, and republishing the service. This article describes the workflow to remove the z-values and m-values of a feature layer named 'River' in ArcGIS Pro, whose properties are shown in the image below, where both z-values and m-values are enabled.
The z- or m-values is present in the feature layer from the Source tab of the layer properties.
Procedure
The Feature Class To Feature Class tool has been deprecated and replaced by the Export Features (Conversion) tool.
In ArcGIS Pro, remove the z-values and m-values of the feature class using the Feature Class To Feature Class tool.
  1. Open the ArcGIS Pro project.
  2. In the Geoprocessing pane, search for and click the Feature Class To Feature Class tool. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for steps to do this.
In the Geoprocessing pane, select the first option which is the Feature Class To Feature Class (Conversion Tools).
  1. In the Feature Class To Feature Class pane, configure the Parameters tab as follows:
    1. Select the feature layer from the Input Features drop-down list.
    2. For Output Location, click Browse The Browse.... icon. to specify the location for the output feature class.
    3. Specify the Output Name.
In the Feature Class To Feature Class pane, configure the parameters in the Parameters tab.
  1. Click the Environments tab, and disable the z-values and m-values.
    1. Expand the Z Values node, and in the Output has Z Values drop-down list, select Disabled. Refer to ArcGIS Pro: Output has Z Values (Environment setting) for more information.
In the Feature Class To Feature Class pane, configure the Z Values node in the Environments tab and select Disabled.
  1. Expand the M Values node, and in the Output has M Values drop-down list, select Disabled. Refer to ArcGIS Pro: Output has M Values (Environment setting) for more information.
In the Feature Class To Feature Class pane, configure the M Values node in the Environments tab and select Disabled.
  1. Click Run. The new feature class created is automatically added to the map.
The image below shows the z-values and m-values are removed from the feature layer in ArcGIS Pro.
The z- or m-values is not present in the feature layer from the Source tab of the layer properties.
Article ID: 000026846
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
