HOW TO
LAZ is a compressed light detection and ranging (lidar) data format that is often used to transfer large amounts of lidar data. ArcMap can process LAS files but not LAZ files. To open and use LAZ files in ArcMap, they must first be converted to LAS using the spatial ETL tool.
The following steps describe how to create a spatial ETL tool to convert LAZ files to LAS. The steps to create a spatial ETL tool are also provided in the following document: Creating a spatial ETL tool.
Note: A Data Interoperability license is required to create the spatial ETL tool.
to navigate to the LAZ file.
button. The Translation Log window is opened. The translation log displays 'Translation was SUCCESSFUL' if the translation process succeeds. The LAS file is created with the extension .las and it is located in the folder specified in Step 2 (f).
Note: The capability to visualize lidar data (in LAS, LAZ, and zLAS file formats) is introduced in ArcGIS Pro 2.1. The Create Scene Layer Package tool can be used to create a point cloud scene layer from lidar data. To do this, refer to Create a point cloud scene layer. The created point cloud scene layer can be published as a service layer, and uploaded to ArcGIS Enterprise or ArcGIS Online using the Share Package tool.
Article ID: 000018224
Get help from ArcGIS experts
Start chatting now
