HOW TO
When working with both ArcGIS Desktop and ArcGIS Pro, the database and server connections established in ArcGIS Desktop can be imported to ArcGIS Pro by connecting to the folder that stores the connection files on the local machine and adding them to a project in ArcGIS Pro.
The database and server connection files (.ags and .sde files) created in ArcGIS Desktop are generally stored in:
C:\Users\<user_name>\AppData\Roaming\ESRI\Desktop10.x\ArcCatalog
This article provides steps to import and rebuild the database and server connections from ArcGIS Desktop in ArcGIS Pro.
Note: The AppData and Roaming folders are hidden by default. Ensure both folders are unhidden before running ArcGIS Pro. If ArcGIS Pro is running while enabling the Show Hidden Folders options in Windows, restart ArcGIS Pro to register the changes.
For more information on adding a folder connection, refer to ArcGIS Pro: Connect to a folder.
Once a connection has been added to a project, add it as a favorite to make it available quickly from any project. Alternatively, use the Add To New Projects option to add the connection automatically to all new projects, as described in: Add an item to all new projects
Article ID: 000016815
Get help from ArcGIS experts
Start chatting now
