HOW TO
Set a display name in the legend in ArcGIS Pro
Last Published: May 26, 2021
Summary
When creating legends in ArcGIS Pro, there are times it may be necessary to use a different name for features than what is listed in the Contents Pane, but still preserve those names. In these cases, it is possible to set up a description name that is similar to a display name.
Procedure
To create a description name follow the steps below:
  1. In Layout view, right-click the feature to start with and select Symbology.
  2. In the Symbology pane for the feature, in the Description section, type a description to display in the legend, as shown in the image below.
Layout view showing Symbology pane for selected feature
  1. Do this for every feature in the map. Once this is done for all features, right-click the legend in the Contents pane and select Properties.
  2. In the Format Legend pane, under Legend Items, select Show Properties, as seen in the screenshot below.
Format Legend items, Show properties
  1. In properties pane, under Legend Item, turn on only Descriptions, as shown in the screenshot below. Once this is done, the description name should display in the legend.
Legend items Show options
Article ID: 000025548
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
