HOW TO
Determine the compass direction of line features in ArcGIS Pro
First Published: August 10, 2023
Last Published: May 28, 2026
Summary
In ArcGIS Pro, directions of line features can be determined by the compass direction. This is important to show the cardinal and ordinal directions used for navigation and geographic orientation.
This article describes the workflow to determine the compass direction of line features in ArcGIS Pro.
Procedure
  1. Use the Linear Directional Mean tool output to obtain the compass angle of the line features.
    1. On the Analysis tab, click Tools to open the Geoprocessing pane.
    2. In the Geoprocessing pane, search for and click Linear Directional Mean (Spatial Statistics Tools).
    3. In the Linear Directional Mean pane, on the Parameters tab, select the line feature class from the Input Feature Class drop-down list. In this example, 'Line' is selected.
    4. Specify a name for Output Feature Class.
    5. Select a field for Case Field from the drop-down list.
The Case Field is used to group features for separate linear directional mean computations. When a Case Field is specified, the input line features are first grouped according to case field values, then an output line feature is created for each group. The case field can be of integer, date, or string type. Records with NULL values for the Case Field are excluded from analysis.
  1. Click Run.
  1. Open the attribute table of the feature class created in Step 1. Refer to ArcGIS Pro: Open a table from a catalog view or the Catalog pane for instructions.
  2. Add a new text field to the attribute table. Refer to ArcGIS Pro: Add Field (Data Management) for more information. In this example, the text field is named 'Direction'.
A new Text field is created
  1. Use the Calculate Field tool to create a Python function to convert the angle values to text direction.
    1. For Input Table, select the attribute table of the feature class created in Step 1.
    2. Select Direction for Field Name.
    3. For Expression Type, select Python.
    4. For Expression, specify the following script in the expression box.
direction(!CompassA!)
  1. Specify the following script in the Code Block box.
The following script defines the direction based on the north of the map. The line continues to take into account the north of the map even if it is tilted.
def direction(var):
   if var < 22.5:
      return "North"
   if var >= 22.5 and var < 67.5:
      return "Northeast"
   if var >= 67.5 and var < 112.5:
      return "East"
   if var >= 112.5 and var < 157.5:
      return "Southeast"
   if var >= 157.5 and var < 202.5:
      return "South"
   if var >= 202.5 and var < 247.5:
      return "Southwest"
   if var >= 247.5 and var < 292.5:
      return "West"
   if var >= 292.5 and var < 337.5:
      return "Northwest"
   if var >= 337.5:
      return "North"
  1. Click OK.
The direction of the line features are displayed in the attribute table as shown in the image below.
The line directions are displayed in the attribute table
Article ID: 000030990
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
