HOW TO
Temporal change can be detected by comparing two rasters from different times, such as detecting changes in vegetation cover or land use over a specified period. This can be done with the Raster Calculator tool or Difference function in ArcGIS Pro, allowing for further interpretation and classification of areas of change.
Note: Using post-processed, enhanced, classified, or normalized rasters provides more accurate change detection results than raw aerial imagery. For example, to detect vegetation cover changes, use aerial imagery to calculate normalized difference vegetation index (NDVI) rasters for different time periods as the first step. To detect land cover changes, classify the aerial imagery into land cover maps before comparing spatial changes over time. Refer to ArcGIS Pro: NDVI and ArcGIS Pro: Overview of image classification for more information.
The images below show NDVI rasters of vegetation cover for years 2005 and 2017. This article provides the workflow to detect and quantify vegetation cover changes using the Raster Calculator tool with the 2005 and 2017 data as an example.
Note: This workflow requires the Spatial Analyst license. Refer to ArcGIS Pro: Enable the Spatial Analyst extension for more information.
Note: The NDVI rasters must cover the same spatial extent, and the pixels must be perfectly aligned. Additionally, to detect annual changes, acquire NDVI rasters calculated for the same window of the year. Otherwise, NDVI rasters calculated in different seasons reflect vegetation changes over seasons, not years.
"<raster of a later time>" - "<raster of an earlier time>"
The output raster contains the subtracted cell values. Negative values indicate losses while positive values indicate gain. Zero ‘0’ indicates unchanged vegetation cover.
A reclassified raster is created with pixel values indicating the vegetation change classes. A Count field is added to the attribute table of the reclassified raster containing the number for cells falling into each class.
The area for each class is calculated in the new field. The unit of the calculated area is the unit of the raster’s coordinate system.
Note: To determine the raster’s coordinate system, right-click the raster layer in the Contents pane and navigate to Properties > Source > Spatial Reference.
Article ID: 000030638
Get help from ArcGIS experts
Start chatting now
