HOW TO
Computer Aided Design (CAD) files can be added to ArcGIS and made to overlay other data in ArcMap by defining the projection (coordinate system).
The instructions provided in this article describe how to define a projection for CAD data in ArcMap and apply it to DWG or DXF files created in AutoCAD and to DGN files created in Microstation.
CAD data can be created in a real-world coordinate system, such as State Plane or UTM. This is the spatial reference of the CAD data, and information about the spatial reference should be obtained from the data source. If the CAD data was created in a real-world coordinate system and the data source provides the necessary parameters, refer to Step 1.
Note: To identify the coordinate system used to create the CAD file, if the data source does not have the projection information available, refer to How To: Identify an unknown projected coordinate system using ArcMap 10.1 and later versions to identify the projection for the CAD file.
Note: To determine whether the coordinate system is geographic, projected, or local, refer to How To: Identify the spatial reference, projection, or coordinate system of data.
on the top ribbon. The ArcToolbox pane opens.
Warning: • The projection file must be saved in the same directory as the CAD file. • With the exception of the file extension, the projection file name must be identical to the CAD file. • The file name is case-sensitive.
Note: The projection is defined for all the CAD files in that directory. This method also defines the projection for any CAD files saved with spaces in the name.
Note: In version 10.x, open ArcMap, and click View > Data Frame Properties > Coordinate System tab. On the Coordinate System tab, browse to the projection definition that applies to the CAD file and right-click it, click Add To Favorites, and click OK. A physical copy of the projection file is written to the location of the user profile.
Article ID: 000007831
Get help from ArcGIS experts
Start chatting now
