HOW TO
Create a square buffer around a point feature
First Published: May 5, 2016
Last Published: May 24, 2022
Summary
The Buffer tool creates polygons around the input features at a specified distance. When buffering points, the output is circular by default. The instructions provided describe how to create a square buffer around a point feature.
Procedure
Both options below require an ArcGIS Desktop Advanced license; however, use Option B if the input buffer consists of multipart features. Use either option if the input buffer has singlepart features.
Option A: Use the Buffer and Minimum Bounding Geometry tools
  1. Launch ArcMap, and add the point feature class or shapefile to the map.
  2. Create boundaries around points at a specified distance. Navigate to ArcToolbox > Analysis Tools > Proximity > Buffer, or navigate to Geoprocessing > Buffer.
  3. In the Buffer window, complete the fields. Click OK to run the tool.
  4. Create square polygons for the polygon buffers created above. Navigate to ArcToolbox > Data Management Tools > Features > Minimum Bounding Geometry.
  5. In the Minimum Bounding Geometry window, complete the fields as follows:
    1. Input Features: the buffer polygons created in Step 4
    2. Output Feature Class: the desired output location for square polygons
    3. Geometry Type: ENVELOPE
    4. Group Options: NONE
    5. Click OK to run the tool.
Option B: Use the Buffer and Feature Envelope To Polygon tools
  1. Complete Steps 1 through 3 listed in Option A.
  2. Create square polygons for the polygon buffers created above. Navigate to ArcToolbox > Data Management Tools > Features > Feature Envelope To Polygon.
  3. In the Feature Envelope To Polygon window, complete the fields as follows:
    1. Input Features: the buffer polygons created in Step 2
    3. Click OK.
If input buffers have multipart features, check the Create multipart features (optional) check box.
There is a square buffer around the point feature.
The square buffer is created around the point.
Article ID: 000012502
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
