HOW TO
This article provides steps to let the newly created features have the next number sequence in a field, such as an ID or index field.
Before beginning, ensure the feature to add the sequential values to has a Global ID field. If not, use the Add Global IDs geoprocessing tool.
Create a database sequence using the Create Database Sequence geoprocessing tool.
NextSequenceValue ('Test')
Note: When adding an attribute rule, ensure that the Exclude from application evaluation parameter is enabled or set to true.
Article ID: 000024533
Get help from ArcGIS experts
Download the Esri Support App
