HOW TO
This article was contributed by Esri UK.
Customers in the UK who use Ordnance Survey data are required to watermark any data published electronically to external sources.
Instructions provided describe how to add a watermark to a map service.
Note: Make sure that the layer is positioned in the MXD above all base data and large-area/seamless polygon layers, but below all other data layers.
Article ID: 000011552
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
