Frequently asked question
Does Map Viewer Classic in ArcGIS Online support joins and relates?
Last Published: December 20, 2023
Yes, Map Viewer Classic in ArcGIS Online supports join and relates. ArcGIS Online has the Join Features function as an analysis tool since the December 2016 release of ArcGIS Online. Refer to ArcGIS Online: Join Features (Map Viewer Classic) for more details.
Meanwhile, ArcGIS Online can view or edit layers with related records.
To access the Join Features tool:
  1. Click the Contents button on the Details pane when the web map is opened in Map Viewer Classic.
  2. Click the Analysis Analysis button button, select Feature Analysis, expand the Summarize Data category, and select Join Features.
Join Features under the Summarize Data category in Perform Analysis
If a layer contains related records, the attributes can be edited with the correct privileges, as explained in ArcGIS Online: Edit attributes and related records. These related records are represented as columns with italicized headers on the right side of the attribute table as shown in the image below.
Related records represented for a feature layer's attribute table in Map Viewer Classic.
Article ID: 000012168
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
