Frequently asked question
No, it is not possible to generate population data within overlapped drive-time areas in ArcGIS Business Analyst Web App.
Multiple drive-time areas around the site can be created at specific times or based on road networks. In Business Analyst Web App, business, demographic, and point of interest (POI) data can only be generated for non-overlapping drive-time intervals. Refer to How to: Create a generation report in ArcGIS Business Analyst Web App for more information. However, it is possible to generate population data within overlapped drive-time areas in ArcGIS Pro. The exported drive-time areas from Business Analyst Web App must be separated individually based on the same drive-time interval before generating population data using the Enrich tool.
Note: Running the Enrich tool consumes credits. Refer to ArcGIS Pro: Geoprocessing tools that use credits for more information.
. Double-click Population > Population Totals and select preferred population data in the Data Browser window. Click OK.Note: Click estimate credits to determine how many credits are used to run the Enrich tool.
Note: Publish the output feature layer to ArcGIS Online as a hosted feature layer for use in Business Analyst Web App, if necessary. Refer to ArcGIS Pro: Share a web feature layer using the default configuration for more information.
Note: Alternatively, publish the overlapped drive-time feature layer to ArcGIS Online and enrich the published feature layer in Map Viewer or Map Viewer Classic using the Enrich Layer tool. Refer to How to: Perform data enrichment on a layer in ArcGIS Online for more information.
Article ID: 000033632
Get help from ArcGIS experts
Start chatting now
