Frequently asked question
Can a web map be set to read-only in ArcGIS Online?
First Published: February 28, 2024
Last Published: March 19, 2026
No, a web map cannot be set to read-only mode in ArcGIS Online. Even if all editing capabilities are disabled in ArcGIS Online before publicly sharing the web map, viewers still retain limited editing capabilities. Additionally, certain features such as layer properties, associated tools, and the name of the feature layer view in the pop-up remain visible in the ArcGIS Online web map, preventing it from being entirely in read-only mode.
Alternatively, use the workflow below to set the web map to read-only in ArcGIS Experience Builder.
  1. Log in to ArcGIS Online and click Content > My content.
  2. Search for and click the web map.
  3. On the item page, click Create app and select Experience Builder.
  4. On the template gallery of Experience Builder, browse to the Blank fullscreen template and click Create.
The template gallery in ArcGIS Experience Builder
  1. On the canvas, click and extend the Map widget to the intended size, as shown below.
The map extended to the corners of the layout in Experience Builder.
  1. On the Map panel, under Tools, disable all the tools.
The tools in the Tools section, all disabled.
  1. Under Options, toggle Enable scroll zooming and Enable pop-up on.
The Enable scroll zooming and Enable pop-up toggles enabled in the Options section.
  1. Click Save The Save icon. > Publish.
The Experience Builder map below is successfully set to read-only.
The web map in read-only mode.
Article ID: 000032029
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
