HOW TO
Extract server and database properties from layers in an MXD file
Summary
GIS administrators and managers sometimes need to ascertain the server and database properties of layers in .mxd files in an automated fashion. Instructions provided describe how to do this using a Python script.
Procedure
The below Python script demonstrates how to extract database and server properties for layers and tables in an .mxd file.
  1. Modify the below parameter to point to an .mxd file:
mxd_source = r"C:\DATA\test_name.mxd"
  1. Run the following script.
import arcpy, os, string
def FindConnPropTbl(mxd_source):
    mxd = arcpy.mapping.MapDocument(mxd_source)
    for df in arcpy.mapping.ListDataFrames(mxd):
        tableList = arcpy.mapping.ListTableViews(mxd, "", df)
        for table in tableList:
            dsource = str(table.dataSource)
            fnd = dsource.find('.sde')
            sub_str = dsource[:fnd +4]
            desc = arcpy.Describe(sub_str)
            cp = desc.connectionProperties
            try:
                print "Table:{0},Server: {1}".format(table.name,cp.server)
            except:
                print "No server listed for table: {0}".format(table.name)
            try:
                print "Table:{0},Database: {1}".format(table.name,cp.database)
            except:
                print "No database listed for table: {0}".format(table.name)
            del table,dsource,fnd,cp,sub_str,desc
    del mxd,df,tableList
def FindConnPropFc(mxd_source):
        layerList = arcpy.mapping.ListLayers(mxd, "", df)
        for layer in layerList:
            dsource = str(layer.dataSource)
            try:
                print "Layer:{0},Server: {1}".format(layer.name,cp.server)
            except:
                print "No server listed for layer: {0}".format(layer.name)
            try:
                print "Layer:{0},Database: {1}".format(layer.name,cp.database)
            except:
                print "No database listed for layer {0}".format(layer.name)
            del layer,dsource,fnd,cp,sub_str,desc
    del mxd,df,layerList
if __name__=="__main__":
Article ID: 000011781
Software:
  • Legacy Products
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
