ERROR
The layer, '<Basemap Name>', is not compatible with the current basemap. To add the layer, add it to the map as the basemap
Last Published: April 18, 2023
Error Message
When a layer is added to a map, the basemap is removed, and when attempting to add a basemap, it fails and returns the following error:
Error:
The layer, '<Basemap name>', is not compatible with the current basemap. To add the layer, add it to the map as the basemap.
Error Message
Cause
This is an expected behavior. Different basemaps use different spatial references. When a layer using a different spatial reference is opened in Map Viewer, the basemap is removed from the map. In the example above, the tile layer is not compatible with the World Topographic Map basemap from Living Atlas.
Solution or Workaround
Use one of the following solutions to solve the issue:
Article ID: 000030024
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
