ERROR
System.Net.WebException when using json file in IIS wwwroot for HTTP counter
Error Message
In ArcGIS Monitor Administrator, the following error may be returned when the URL for the Http counter is set to https://<hostname>.<domain>.com/<jsonfile>.json using the IIS wwwroot folder in C:\inetpub\wwwroot.
Error: System.Net.WebException when using json file in IIS wwwroot for HTTP counter
Cause
This error occurs because IIS does not serve that mime type by default. In addition, the URL contentType in ArcGIS Monitor is not expecting .json format. The solution to this error is to change the .json file to a .txt file.
In ArcGIS Monitor 10.7, an enhancement was made for the contentType to accept *.* format, to address this issue. Even with this enhancement in 10.7, IIS does not serve that mime type without configuring  IIS to process JSON.
Solution or Workaround
ArcGIS 10.6.x
  1. In the C:\inetpub\wwwroot folder rename the .json file to .txt.
  2. In ArcGIS Monitor Administrator, Add the Http counter.
Article ID: 000019548
Software:
  • ArcGIS Monitor Administrator
  • ArcGIS Monitor Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
