ERROR
Opening an MXD file in ArcMap returns the error message:
Error: Opening the selected ArcMap document failed. This map document was saved using a newer version of ArcGIS. To save a map document from a newer version of ArcGIS so it can be opened in an earlier version, use the File > Save A Copy command.
The error message is returned when an older version of ArcMap is used to open an MXD file created in a newer version. For example, using ArcMap 10.5 to open an MXD file created in ArcMap 10.6.
To resolve this issue, the creator of the MXD file can use the Save A Copy command in ArcMap to save the file for a specific version of ArcMap, allowing other users to view it.
Note: Alternatively, upgrade to the latest version of ArcMap to read the MXD file.
Article ID: 000021004
Get help from ArcGIS experts
Start chatting now
