ERROR
Hmm... there seems to be an issue. We were unable to sign you in using those credentials. Please contact your ArcGIS administrator for assistance
First Published: February 17, 2022
Last Published: February 17, 2022
Error Message
When an organization administrator or item owner attempts to view a story map, the following error message is returned:
Error:
We were unable to sign you in using those credentials. Please contact your ArcGIS administrator for assistance.
The error message
Cause
  • The organization member’s user type has insufficient privileges to access ArcGIS StoryMaps.
  • The Essential Apps add-on license is not assigned to the organization member.
Solution or Workaround
Depending on the cause, use one of the following options to resolve the issue.
Only organization administrators can perform the following workflows.
Update the member’s user type with privilege to access ArcGIS StoryMaps
Change the member’s user type to Creator. Refer to ArcGIS Online: Change user types for instructions and more information.
Assign the Essential Apps add-on license to the member
By default, the Essential Apps Bundle is not included in the Insights Analyst, Advanced, or Standard user type. To access ArcGIS StoryMaps, organization administrators or members with licensing privileges must manually assign the Essential Apps add-on license to the member. Refer to ArcGIS Online: Configure add-on licenses for multiple products for instructions and more information.
The App bundles window with the Essential Apps add-on license.
Share the story map publicly
Share the story map publicly to enable the member to view it in ArcGIS StoryMaps. Refer to ArcGIS Online: Share items with everyone for instructions and more information.
Article ID: 000027217
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
