HOW TO
Delete records from a table or layer using ArcMap
Last Published: January 4, 2022
Summary
This article provides two methods for deleting records from tables or the attribute table of a layer. Deleting records does not affect the schema of the table.
Procedure
Manual deletion
  1. From the Editor toolbar, click the Editor drop-down menu > Start Editing.
  2. Right-click the layer and open the Attribute Table.
    • If it is a standalone table, right-click it and click Open.
  3. Select the records to delete.
  4. Click the Delete button.
    • To undo any changes applied, click the Undo button located in the Standard toolbar. If the Edit session is finished, the changes cannot be reverted.
Using the Delete Rows tool
  1. Open the Delete Rows tool from the Data Management toolbox > Table toolset.
  2. Select the input table/layer.
    • For deleting records from multiple layers, Batch processing can be performed: right-click the tool and click Batch, then select all the layers required
  3. Click OK and all records will be deleted.
    • If a selection is applied, the tool deletes the records selected only.
Article ID: 000026967
Software:
  • ArcGIS Desktop
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
