PROBLEM
When exporting the table of a feature class with coded value domain descriptions in ArcMap, the coded value is displayed instead of the descriptions.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012593/00N39000003LL24-0EM39000000wdgz.png)
This is a known limitation. ArcGIS, by default, exports domain codes instead of domain descriptions.
Select one of the solutions shown below. Option A allows the particular table to display the coded value domain descriptions, whereas Option B allows all tables exported to display the coded value domain descriptions. Option C can be used to display both coded domain values and descriptions.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012593/00N39000003LL2C-0EM39000000wdh3.png)
Change the Environment settings, and use the Table to Table tool.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012593/00N39000003LL2C-0EM39000000wdh7.png)
Note: Option C adds a new field for domain descriptions. For more information on exporting a feature class to a shapefile containing domain descriptions instead of domain codes, refer to the following article, HowTo: Export a feature class to a shapefile that contains domain descriptions instead of domain codes.
Article ID: 000012593
Get help from ArcGIS experts
Start chatting now
