Frequently asked question
Can a Database Connection file created in ArcGIS 10.1 be used in an ArcGIS 10 or 9.3.x client?
Answer
For the majority of cases, connection files created at 10.1 will be usable at previous releases of ArcGIS Desktop. Only connection files created at 10.1 in the following three ways cannot be used at previous releases of ArcGIS Desktop:
1. Database Authentication is being used and the user name and password are being saved with the connection file.
2. Connection syntax is not supported at previous ArcGIS releases, such as Oracle Easy Connect syntax or when IBM DSN-less connection strings are being used in the instance parameter.
3. The connection is being made to an enterprise geodatabase at a version that is not supported by the release with which it is intended to be used.
Article ID:000011631
Software:
  • ArcMap
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
