PROBLEM
Bookmarks created in ArcMap do not import to a hosted web map in ArcGIS Online
First Published: May 5, 2016
Bookmarks created in a map document in ArcMap fail to display when the map is published in ArcGIS Online as a hosted web map.
Cause
This is a known limit.
Bookmarks are created in a map document and stored directly in the map document JavaScript Object Notation (JSON), and are unique to a particular map document. They cannot be moved independently, and are not preserved in the web map.
Solution or Workaround
Re-create the bookmarks in the ArcGIS Online web map after the map is published.
See the link in the Related Information section below to learn how to create a new bookmark in ArcGIS Online.
    Article ID: 000012309
    Software:
    • ArcGIS Online
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
