PROBLEM
ArcGIS Pro may crash or display unexpected character issues, including showing diamond and square symbols instead of valid characters, when the beta setting ‘Use Unicode UTF-8 for worldwide language support’ is enabled in Windows Region settings.
The beta setting 'Use Unicode UTF-8 for worldwide language support' can be problematic in conjunction with ArcGIS software. This setting may be enabled by default.
When experiencing crashes or character encoding issues in ArcGIS Pro and ‘Use Unicode UTF-8 for worldwide language support’ is enabled, disable this setting and test the behavior again. When not using ArcGIS Pro, the setting can be enabled for use with other non-ArcGIS software.
If this issue persists, contact Esri Technical Support for additional assistance.
Article ID: 000024027
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
