HOW TO
Currently, there is no out-of-the-box tool to add a feature class to an existing replica. With ArcGIS Desktop, one must either recreate the replica or, if the workflow allows, replicate the new feature class as a separate replica.
A feature class or table can only be added to an existing replica (without recreating the replica) using ArcObjects code.
Note: This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed. ArcGIS software features were deprecated, rather than immediately removed, to provide customers with backward compatibility and give as much advance notice as possible to adopt newer technology.
ArcObjects:
Use the instructions in How to add a feature class or table to an existing replica to add the feature class to the replica by way of ArcObjects code.
Desktop:
The steps below outline how the recreate the replica using the Register Existing Data option in Desktop. These steps can be applied to both one-way and two-way replicas.
Note: The GlobalIDs must have already been added to the feature class.
Article ID: 000010345
Get help from ArcGIS experts
Start chatting now
