HOW TO
Leeren oder Löschen des Trusted Storage für Concurrent- und Single-Use-Lizenzen
Last Published: April 10, 2025
Zusammenfassung
It is sometimes necessary to clear out the trusted storage for ArcGIS 10.x licensing. The instructions provided describe how to do this.
The steps described in this procedure include deleting files that may be hidden. To display hidden files, follow the directions in this Windows support document.
Vorgehensweise
To clear out the trusted storage:
  1. Close the License Administrator.
    • For concurrent-use licenses, stop the License Manager service (License Server Administrator > Start/Stop License Service) and close the License Server Administrator.
    • For single-use licenses, close the ArcGIS Administrator.
  2. Navigate to the FLEXnet folder. The locations of the trusted storage on a Windows machine for concurrent-use and single-use are as follows:
    • Windows XP and 2003 Server:
C:\Documents and Settings\All Users\Application Data\FLEXnet
    • Windows Vista, 7, 8, 10, 11, Server 2008, Server 2012, Server 2016, Server 2022:
C:\ProgramData\FLEXNet
The ProgramData folder is hidden by default. Refer to Microsoft: View hidden files and folders in Windows for instructions on viewing hidden folders.
    • Location of the trusted storage on a UNIX/Linux machine for concurrent-use:
/usr/local/share/macrovision/storage
  1. Either remove all of the ArcGIS_xxxxxxxx_tsf.data files within the FLEXNet folder, or create a new folder and move the files into the new folder. Make sure to remove the ArcGIS_xxxxxxxx_tsf.data files from the FlexNet folder.
  2. Verify that the licenses are removed.
    • For concurrent-use licenses, start the License Manager service (License Server Administrator > Start/Stop License Service) and close the License Server Administrator. Click the Availability folder to verify it has been cleared.
    • For single-use licenses, open the ArcGIS Administrator and click the Availability folder.
  3. Reauthorize the license. If unable to authorize licenses after following this process, refer to How To: Recover lost licenses from My Esri for more information.
Artikel-ID: 000011660
Zugehörige Informationen
Zu Download-Optionen wechseln
