HOW TO
This article describes the workflow to install an Esri StreetMap Premium .sdlic license file to a machine that has ArcGIS for Server installed, but not ArcGIS for Desktop.
If ArcGIS for Desktop is installed, to install the StreetMap Premium license file, simply click All Programs > ArcGIS > ArcGIS Administrator > Data Licenses > Add a license. If ArcGIS for Desktop is not installed, this workflow cannot be utilized, as ArcGIS Administrator is also not installed.
This workflow involves utilizing the Windows Command Prompt, the .sdlic license file, and a .exe utility included with the ArcGIS Server installation.
cd C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin
Note: For ArcGIS Enterprise 10.9 and below, the bin directory is 'C:\Program Files\ArcGIS\Server\bin'.
C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin>
DataLicInstall.exe C:\FolderName\<nameOfLicenseFile>.sdlic
Article ID: 000012654
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
