PROBLEMA
Fallo de carga de LoadLibrary con error 126 o error 87 al funcionar en remoto por RDP
Last Published: May 3, 2024
Descripción
When working remotely to access ArcGIS Software, users rely on RDP (Remote Desktop Protocol) connections to use ArcGIS Desktop applications.
In some cases, the following errors may be encountered when launching ArcMap, ArcGIS Pro or other ArcGIS software:
Error:
LoadLibrary failed with error 126: The specified module could not be found.
or,
Error:
LoadLibrary failed with error 87: The parameter is incorrect.
Image of the error message
Causa
When using RDP to connect to a remote machine, the error could be related to the RDP session itself. However, what may be occurring is a conflict between the video card specified by the RDP connection, and the one used by ArcMap on the remote machine. RDP is connecting by default to a built-in Intel video card, and not the video card used by ArcMap.
The solution is to disable the Intel video card, and restart the RDP session, forcing it to use the video card on the computer used by ArcGIS.
Id. de artículo: 000023067
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
