Frequently asked question
The workflow is provided as a set of best practices for troubleshooting ArcGIS Pro crashes, but it can be extended to other desktop applications like ArcGIS Desktop or ArcGIS Drone2Map.
Before beginning, make sure to understand the full context. This workflow might offer a straightforward solution, but that is not always the case. Sometimes the outcome is complex, so it is necessary to analyze more aspects of the scenario. For example, how to address a case where ArcGIS Pro crashes, as the solution may vary depending on whether the crash occurs during initialization or when opening a specific project.
Here is a list of aspects to check:
Note: The dump file name's structure also provides information such as the product name, version, the time and date of its creation:![]()
The images and their paths can fall into four categories with different ways to understand the crash and the best possible solutions:
Software Corruption
The most common images associated are those with paths in the installation location, which by default is C:\Program Files\ArcGIS\Pro\bin. Here are just a few examples:
To fix the issue, try the following workflows:
Graphics Card Conflict
The most common images associated are:
Reach out to IT to ensure the graphics card drivers are up-to-date, working properly, and fully compatible with ArcGIS Pro. As a temporary solution (and only if there is more than one graphics card), follow the steps described in How To: Set ArcGIS Pro to run with a different graphics card to run ArcGIS Pro using the functioning card while the other one is repaired.
Note: Bear in mind that troubleshooting graphic cards is outside of Esri's Scope of support.
A conflict with the machine's components
Some images related to these conflicts are:
To determine the component causing ArcGIS Pro to crash and the best possible solution, further investigation is required according to the specific module involved. However, sometimes with just reinstalling, updating (ensuring compatibility), or disabling/enabling these components, the issue can be solved. Reach out to IT for better guidance since troubleshooting machine components is outside of Esri's Scope of support.
Third-party software, add-ins, and others
In these scenarios, the dump file may include the name of the tool and/or add-In instead of the software. Further investigation is required according to the specific module result; reach out either to IT or the third party for better guidance.
Article ID: 000026378
Get help from ArcGIS experts
Start chatting now
