HOW TO
Note: This is a partial solution to a situation that allows running ArcGIS Desktop with a functioning graphics card, while fixing an affected card that may be causing the software to crash. Is important to understand that troubleshooting graphic cards is beyond Esri's Scope of Support, and it is advisable to follow the workaround described in the Esri Knowledge Base article: Problem: Graphics card conflict may cause ArcMap to crash.This workaround can be performed for ArcGIS Desktop applications when crashes occur because of conflicts with a graphics card. In this scenario, the computer has more than one graphics card. This can be determined by opening the Windows Device Manager > Display Adapters on the computer.
C:\Program Files (x86)\ArcGIS\Desktop10.8\bin\ArcMap.exe
Article ID: 000025975
Get help from ArcGIS experts
Download the Esri Support App
