PROBLEM
Services are not listed in the ArcGIS REST Services Directory
First Published: June 8, 2023
Last Published: June 8, 2023
After upgrading ArcGIS Enterprise, services available in ArcGIS Server Manager and Portal for ArcGIS are not listed in the ArcGIS REST Services Directory in a federated environment, as shown in the image below:
Services are not listed in the ArcGIS Server REST Directory
Cause
  • The account accessing the services do not have to necessary permissions to the service folders.
  • The ArcGIS Server services folders are missing.
Solution or Workaround
Use one of the following workflows to resolve the issue:
Clear the browsing cache
Clear the web browser cache depending on the web browser used:
Check the service directories if the services are still present
Default ArcGIS Server services and created services are stored in the following directories:
  • Default services:
C:\arcgis\arcgisserver\config-store\services
  • Created Services:
C:\arcgis\arcgisserver\directories\arcgissystem\arcgisinput
Navigate to these folder to check if these folders are still present. If the folders are not present, consider doing the following:
If the services are still present in these folders, check if the service account accessing these services have the full control permissions to these folders. Refer to the Solution or Workaround section of Problem: Unable to access REST endpoint after changing the ArcGIS Server account for instructions.
Article ID: 000030479
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
