PROBLEM
Unable to access federated ArcGIS Servers
Last Published: January 26, 2023
Attempts to access federated ArcGIS Servers fail, and the following error message is returned:
Error:
Error code 403. Access to this resource is not allowed. Access to this resource is forbidden.
In some cases, running the analysis tools from Portal for ArcGIS Map Viewer Classic fails, and the following error message is returned:
Error:
Unable to access the analysis service.
The image of the returned error message when running the analysis tools in Portal for ArcGIS Map Viewer Classic.
Cause
The errors occur if the server URL is configured incorrectly when federating ArcGIS Server with Portal for ArcGIS. For example, in the case below, a slash (/) is added after 'arcgis' in the URL, which is incorrect.
https://machine.domain.com/arcgis/
The default URL configuration is:
Solution or Workaround
  1. Log in to the ArcGIS Server Administrator Directory with an administrator account, and click security.
The image of the security option being selected in the ArcGIS Server Administrative Directory window.
  1. In the ArcGIS Server Administrative Directory window, under Security, click config.
The image of the config option being selected in the ArcGIS Server Administrative Directory window.
  1. On the Security Configuration page, navigate to the bottom page and click update.
The update option is being selected on the Security Configuration page.
  1. On the Update Security Configuration page, navigate to Portal properties under the Configuration Properties section.
  2. Search for the serverUrl property, and edit the URL to follow theĀ format described below.
Ensure there are no additional slashes at the end of the URL.
  1. Click Update.
The image of the Update Security Configuration page.
Article ID: 000023713
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
