PROBLEM
Unable to access REST endpoint after changing the ArcGIS Server account
First Published: October 15, 2021
Last Published: July 29, 2025
The REST endpoint can access every GIS Service published on ArcGIS Server using the following URL:
https://<host name>/arcgis/rest/<ServiceName>
In some instances, changing the ArcGIS Server server account causes the REST endpoint to be inaccessible.
Cause
The new ArcGIS Server account lacks the necessary permissions to the ArcGIS Server folders.
Solution or Workaround
After changing the ArcGIS Server account, provide permissions for the new ArcGIS Server account to the ArcGIS Server folders in the following directories:
C:\Program Files\arcgis\server\
C:\Program Files\arcgis\server\framework\
C:\Program Files\arcgis\server\usr\
C:\Program Files\arcgis\server\bin\
C:\Program Files\arcgis\server\XMLSchema\
C:\Program Files\arcgis\server\DatabaseSupport\
C:\arcgisserver\ (or where the config-store and directories are located)
Follow these steps to provide permission for the ArcGIS Server folders:
Completing this workaround may require assistance from the organization's IT department.
  1. Navigate to the DataStore and arcgisdatastore directories.
  2. Right-click the folder and click Properties.
  3. Click the Security tab.
  4. Select the ArcGIS Server account from the Group or user names list.
  5. Click Edit... Edit icon.
  6. Check the Allow option for Full control.
  7. Click OK.
  8. Restart the ArcGIS Server service. Refer to ArcGIS Server: Start and stop services for steps to do so.
Article ID: 000026603
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
