PROBLEM
Some ArcGIS releases require a patch (MSP) to be installed on the existing installation before an upgrade can take place. The required patches for an upgrade are usually installed by Setup.exe. On Windows 11 25H2, the patches are not installed by Setup.exe, and as result the MSI is launched, and returns a message that a patch is required to upgrade.
For example, when upgrading ArcGIS Server, the following message is returned:
The ArcGIS Server 11.4 Upgrade Patch is required to upgrade to ArcGIS Server 11.5. This patch is available in the Support folder.
The affected installations are as follows:
Setup.exe isn’t correctly identifying Windows 11 25H2 as a supported operating system.
Manually install the patches and run the Setup.exe again. The patches required for the upgrade can be found with the other setup files.
Patches can be found in the extracted setup files location such as:
C:\Users\<userprofile>\Documents\...\SetupFiles\Support\Patch
Article ID: 000038958
Get help from ArcGIS experts
Start chatting now
