PROBLEM
Impact of Google Chrome and Microsoft Edge 127 updates on ArcGIS Enterprise
Last Published: October 23, 2025
An update is coming to Google Chrome and Microsoft Edge in July 2024 that will negatively impact and break key parts of the ArcGIS Enterprise portal experience for ArcGIS Enterprise 11.2 and earlier versions.  This affects ArcGIS Enterprise deployments on Windows, Linux, and Kubernetes.
Esri will be releasing a series of patches, starting this month, to resolve this issue.  All ArcGIS Enterprise deployments whose users interact with the ArcGIS Enterprise portal and ArcGIS Enterprise-based web applications in ArcGIS Enterprise 11.2 or earlier, using Google Chrome or Microsoft Edge, must install these patches to avoid disruptions in your web applications.
Cause
The Chromium open-source project that powers Google Chrome and Microsoft Edge is removing an old, obsolete piece of web technology called mutation events.  In this Chromium 127 update, support for these events will be removed, causing global navigation bars on web pages dependent on this technology to appear blank (see Figure 1 below).
Figure 1 - ArcGIS Enterprise global navigation bar as it should appear in Chrome and Edge browsers. If the patch is not installed, this will appear blank.
All versions of ArcGIS Enterprise 11.2 and earlier are affected. ArcGIS Enterprise 11.3 is unaffected. This impacts ArcGIS Enterprise deployments on Windows, Linux, and Kubernetes. ArcGIS Online, esri.com, and other affected web properties that include the global navigation bar have already been updated and will be unaffected.
This change is slated to go into effect with the release of Google Chrome 127 and Microsoft Edge 127. The impact of this will be seen this as soon as web browsers are updated.  Google Chrome will start being updated to Chrome 127 beginning July 23, 2024.  Users of Microsoft Edge will start being updated beginning July 25, 2024.
Rollout of new browser versions is often uneven and individual end users may be affected at different times, depending on when their browser version is updated.  End users will need to refer to their individual web browser to see what Google Chrome version or Microsoft Edge version they are using.
Anyone accessing ArcGIS Enterprise or ArcGIS Enterprise-based web apps through Google Chrome 127 or Microsoft Edge 127 will see different parts of the ArcGIS Enterprise portal and web apps work or draw incorrectly.
Most notably, the top navigation bar will fail to draw entirely and show a blank space instead (see Figure 2 below).
Figure 2- ArcGIS Enterprise global navigation bar, which will be missing in impacted versions with the Google Chrome and Microsoft Edge 127 updates.
Solution or Workaround
To address changes in the Google Chrome and Microsoft Edge 127 updates, Esri will be releasing a Portal for ArcGIS Application Display Patch for affected versions of ArcGIS Enterprise that are within General Availability or Extended Support according to the ArcGIS Enterprise product lifecycle. Patches will be available for versions 11.2, 11.1, 10.9.1, and 10.8.1. Note that there will only be patches released for Windows and Linux and not Kubernetes, which has its own unique product lifecycle.
VERSIONIMPACT OF CHROME AND EDGE 127 UPDATESPATCH PLAN
ArcGIS Enterprise 11.3UnaffectedNo patch.
This version already includes relevant fixes.
ArcGIS Enterprise 11.2AffectedPortal for ArcGIS Security 2025 Update 2 Patch  Released June 12, 2025
ArcGIS Enterprise 11.1AffectedPortal for ArcGIS Security 2025 Update 2 Patch  Released June 12, 2025
ArcGIS Enterprise 11.0AffectedNo patch.
Esri encourages upgrading to 11.3 since 11.0 entered Mature Support in February 2024.
ArcGIS Enterprise 10.9.1AffectedPortal for ArcGIS Security 2025 Update 2 Patch  Released June 12, 2025
ArcGIS Enterprise 10.9AffectedNo patch.
Esri encourages upgrading to 11.3 since 10.9 entered Mature Support in November 2022 and was retired June 1, 2024.
ArcGIS Enterprise 10.8.1AffectedPortal for ArcGIS Application Display Patch  Released July 2, 2024
ArcGIS Enterprise 10.8 and priorMay be affectedNo patches.
Esri encourages upgrading to 11.3.  All versions prior to 10.8.1 are either in Mature Support or have been retired.
If ArcGIS Enterprise 11.2, 11.1, 10.9.1, or 10.8.1 is deployed, apply the relevant patch as soon as possible after it is released for their version of ArcGIS Enterprise.
If unable to upgrade to a patchable version of ArcGIS Enterprise or unable to apply the patch prior to the release of Google Chrome 127 and Microsoft Edge 127, an enterprise policy setting is available in Chrome and Edge to delay the implementation of this breaking change to a later version of Chrome and Edge.
Google Chrome and Microsoft Edge both support the concept of enterprise policy settings that affect the behavior of those browsers. Both browsers are introducing a new policy setting called MutationEventsEnabled that can be used to delay the effective date of this change.  When enabling this setting, the change will not go into effect until Google Chrome 135 and Microsoft Edge 135.  This will provide about nine additional months to either install the necessary patch or upgrade to a new version of ArcGIS Enterprise.
Article ID: 000032813
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 10 8 x
  • ArcGIS Enterprise 10 9 x
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
