HOW TO
In ArcGIS Pro, table frames dynamically display feature attributes within a layout. By default, when table frame fields are wrapped, the headers may appear off-center, resulting in uneven spacing and an unbalanced appearance. In certain scenarios, center-aligning the table frame header is necessary to improve readability, meet standard formatting requirements, or optimize space utilization.
Although a vertical alignment option is available in the Position properties, it does not apply to table frame headers because the alignment is constrained by the space defined within an element. In this article, the Table Frame element is used as an example. However, vertical alignment can be manually adjusted using the Offset Y option in the Position property. This article provides the workflow for vertically center-aligning table frame headers using the Offset Y option in an ArcGIS Pro layout.
This workflow uses a table frame with uneven spacing as an example, as shown below.
The image below shows the center-aligned table frame header in the ArcGIS Pro layout.
Article ID: 000035137
Get help from ArcGIS experts
Start chatting now
