PROBLEM
The Query option for stand-alone tables in the Format Table Frame pane is inactive in ArcGIS Pro
First Published: May 21, 2020
Last Published: June 23, 2026
The Query option is inactive when a stand-alone table is selected from the Table drop-down list in the Format Table Frame pane. Therefore, rows from the stand-alone table cannot be updated dynamically in the Table Frame based on a map series, as the 'Map series rows' option from the Query drop-down list is unavailable.
Image of the Format Table Frame pane with the Query option inactive
Cause
This is a known limitation, as stand-alone tables are not visible in the map extent. Refer to ArcGIS Pro: Modify a table frame for more information.
Solution or Workaround
A workaround is to create a spatial join between the stand-alone table and an index feature class within the map extent to add the required rows from the stand-alone table to the feature class attribute table. Refer to How To: Join an Excel spreadsheet to a feature class in ArcGIS Pro for steps to do this.
These rows can be queried as a map series when the feature class attribute table is selected from the Table drop-down list in the Format Table Frame pane.
Article ID: 000022754
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
